Clutch Actuator Breakage!
I've broke the clutch actuator teeth on the rod and the other semi-circular piece twice.
The clutch spring pressure I need is too much for the parts to handle.
Who could fab me some replacement parts that are stronger? Not production, just done by hand in the shop.
Does anyone know if the 2004 DS has upgraded these parts?
Does anyone know if the BMW FI GS has upgraded these parts?
Is there anything that can be done after the fact to the OEM metal parts to increase their strength?
Originally posted by: Majorecho
Scooby,
been meaning to ask you where you got your swing arm??
Scooby,
eyeball engineering has DS swingarms as does timmyboy - looks like timmyboys lowers the rearend for you???
http://www.eyeballeng.com/swingarms.htm
Originally posted by: SOSA750
I HAD A POST BUT THEY TOOK IT OFF , ANY WAYS THE CLUTCH ACTUATOR FOR A OLDER DS IS PART #420259202, THE 04' PART #IS 420259203. THEY OBVIOUSLY HAD PROBLEMS AND CHANGED SOMETHING. GOOD LUCK, PM IF ANY MORE QUESTIONS
why did they delete your post?
