Turbo or superchager?
#23
#25
#27
The muffler packing burned up twice on me after a couple weekends of riding. Sent it back once and had it re-packed. 2 weeks later the muffler needed re-packing again and the header pipe coating started to flake off, and there were cracks/holes in the header pipe as well. Sent the muffler & header back, waited over a month for it and finally received a call from wood saying to return the entire kit for a refund.
Returned the DS to stock form and the DS ran great for the first time in months. But, soon after engine problems showed up. Coolant was low. Topped it off and found no leaks. Next weekend coolant low again. Flushed coolant system and re-filled. Next weekend coolant empty, DS running strange, milky oil, milky foam coming out of crankcase breather hose into airbox. In shop for months. New cylinder head, piston, rings, valves, etc under warranty. Had bent exhaust valves, dinged piston, cracked head.
#28
Ive been looking over this for a while because it interests me. But I have to say You guys are crazy for waiting on a marginal pice of equipment, I would not be rushing alba to do anything. They need to get this worked out before they sell it to you guys or it will be an expensive hand grenade. As far as turbo goes it is going to be way too expensive, do you remember the dirtwheels with the 400ex turbo. Thousands of dollars for sensors and computers, pop off valves etc. since supercharging works off of the crank, (or sprocket) it is constantly charging, with no lag to spool up go like a turbo. If you are going to hound Alba atleast hound them to build the Supercharger first.
#29
That's what alba is building a supercharger not a turbo. And I'm pretty sure Alba's kit will not be any worse than the wood rotax stage I kit, that me and scooby bought a long time ago. That's why I didn't go with the stage II or III yet, I want to see results of this supercharger kit first. You want lower compression if your going to supercharge.
#30
