Drag pipe for DS
Annihilator...sorry my drag pipes didnt help you like i thought they would have..[img]i/expressions/face-icon-small-sad.gif[/img]...They helped me out alot maybe it was b/c my motor was stock???I mean when I had them on my ds they performed better than my Woods did...dont know why but they did...
Tate, no worries bro, Ill try them with my other motor on alky, you never know they may work good still, but I was just shocked at the performance of the single drag pipe.
Originally posted by: ANNIHILATER
I dont have any pics of the duals...They are really straight head pipes that dump on each side under each foot peg, they are width of the RW head pipe with 2 mild bends( I dont think they flow like this down pipe)..I noticed such a bigger gain from this drag pipe that I have to gear completely different due to different torque range...It feels like I am running bigger cams also, I run smaller cams for the hill and It streched out my gears quit a bit and even helped up top, but I still need to go taller due to more bottom end, probably 17-35 w\hard 2nd gear launch.. Talk to Eric about the theory of his pipe, I think he designed it and adjusted it running on the dyno..I think. If I get the Pami cylinder and run a 108mm lightweight piston (stock stroke) It will really let the motor breath with the pipe..Scooby, If I can make it to Glamis in a few weeks I will let you ride the bike with both pipes so you can see what I am talking about.
Originally posted by: ScoobyDFW
a dual drag pipe setup should make more peak power in theory. who makes the dual drag pipe? is there a pic of the dual drag pipe?
I know I'm always looking for MoRe HorsePower, sounds like you found it!
[img]i/expressions/face-icon-small-smile.gif[/img]
I know I'm happy so far with my set up, nothing what you have so far but trying!
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
