It Is Finished- 46hv vs TM45
Old Feb 5, 2004 | 07:57 PM
  #81
Jerfinds's Avatar
Default It Is Finished- 46hv vs TM45
For those looking for a idea on the stock snorkel with K&N. Check out my pics, I made this from a street sign. Just use the airbox to get the right hole size and cut out the alluminum and bend the top 90 deg and bolt through the fender bolts. I did a lot of polishing to bake it look like that. Hope this helps.
Old Feb 5, 2004 | 09:56 PM
  #82
OuterLimit's Avatar
There you go ironrod. Build on of these out of billet aluminum and you already have a sale.
Thanks for the pictures Jerfinds, that is EXACTLY what I had in mind. Very nice DS650 you have there by the way, with some really clean custom work.
Phil.
Old Feb 5, 2004 | 10:02 PM
  #83
Sandaholic's Avatar
Jerfinds, I like that mod, simple and clean. Where did you relocate the rectifier to?
Old Feb 5, 2004 | 10:19 PM
  #84
ironrod's Avatar
Old Feb 5, 2004 | 11:32 PM
  #85
SANDMAN430's Avatar
isn't that what the guys are saying there finding that the tube actually helps keep horsepower? i know i bought the carb mount a couple years ago thinking it would make a big difference and never seemed to see it. i know i pulled my tube off the shelf yesterday and put it on to see how to mount it under the seat. Anyone have a easy way to plug the vacuum tube vent hole on the side?
Old Feb 5, 2004 | 11:57 PM
  #86
Sandaholic's Avatar
At an auto parts store I found a rubber cap (female) that goes right over the stock vacuum tube vent. I hose clamped it right to the right angle fitting that is part of the vacuum tube.
Old Feb 6, 2004 | 12:44 AM
  #87
BigWaynester's Avatar
Some people are running their crank case breather hose to that hole. This is what I am going to do when I switch back over.
Old Feb 6, 2004 | 01:04 AM
  #88
Sandaholic's Avatar
I though about doing that, but the crank case hose might create disturbance in the air flow. From what I understand the snorkel tube creates more hp by straitening out the air flow and creating a higher velocity. The alternating suction and blow by can't be a good thing.
Old Feb 6, 2004 | 01:25 AM
  #89
Jerfinds's Avatar
I relocated the rectifier to under the tool storage compartment. I drilled two holes in the long skinny part, If you take out the tool bag you will see what I am talking about. Just hold the rectifier up mark where the holes have to be and use the same bolts that were used on the airbox. I will post a pic if I can find one on the computer, If not I will take one tomorrow and post it.
Old Feb 6, 2004 | 01:56 AM
  #90
Maddog419's Avatar
To Jerfinds: I like the way your set-up looks, but I hate to say it. You will only lose H.P. with that set-up. Come-on you guys. Where's some help on this one, I know a lot of ds riders that know better than this. That set-up will not work with a stock C.V. carb or an lectron carb,ect,ect,ect.
(1) Number one----- What part of MR.H.P or BOM or 222, do you guys not understand.
But at the same time I would LIKE TO THANK ALL THAT DID THE CARB SHOOT-OUT. IT WAS GREAT READING.
later
