It Is Finished- 46hv vs TM45
Old Feb 6, 2004 | 06:52 PM
  #101
buttfungus's Avatar
Default It Is Finished- 46hv vs TM45
I'm happy with it, even with the stock cdi box and 87 octane....
Old Feb 6, 2004 | 07:44 PM
  #102
PureIntimidation's Avatar
I dont want to beat this horse to death, but i guess im not understanding it. I have the stock carb, with a direct mount filter. Are you guys saying that i will gain more by putting the snorkle back on? Will I need to up the jets with this setup or lower? Im running a 195 right now, and my bike seems to run spot on. Im all about more free horses so please let me know.
Also, I hear alot of people talking about how awesome MRHP's head job is.. (that didnt sound right did it?) were can I get this done, and how much does it cost?
Also, if i keep my bike I am thinking of going with a 680 kit. What all do i need to do? Is this a good kit to go with? Can i use a1/a2 cams on that set up? Where can I get the kit?
Sorry for all the questions, but you all do seem to have all the answers compared to others i have talked to.
Thanks in advance,
Kenny
Old Feb 6, 2004 | 09:08 PM
  #103
buttfungus's Avatar
The stock cv carb makes more hp with the snorkel and stock air box with lid with the 2 tubes pulled out and zip tied to the frame facing forward using the stock needle at the richest position and 170 mikuni main jet with billet end cap for elevations under 2000 ft or so. Mr Hp's porting on the carb intake is awesome and I have heard his head porting/valves/cam mods are top notch as well.
Old Feb 6, 2004 | 11:43 PM
  #104
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
The 680 kit is a Pami 102mm bore and piston. They bore your jug and re nicisil it to spec. It is in the 11 to 1 area for compression. The cams should fit with no problems. The head has to be clearanced for the bigger bore too.
Old Feb 7, 2004 | 01:16 AM
  #105
OuterLimit's Avatar
Where can I read more about the Pami 680cc kit?
Thanks.
Old Feb 7, 2004 | 01:53 AM
  #106
Jerfinds's Avatar
Originally posted by: Maddog419
To Jerfinds: I like the way your set-up looks, but I hate to say it. You will only lose H.P. with that set-up. Come-on you guys. Where's some help on this one, I know a lot of ds riders that know better than this. That set-up will not work with a stock C.V. carb or an lectron carb,ect,ect,ect.
(1) Number one----- What part of MR.H.P or BOM or 222, do you guys not understand.
But at the same time I would LIKE TO THANK ALL THAT DID THE CARB SHOOT-OUT. IT WAS GREAT READING.
later
Well maddog, good thing I don't have either one of those carbs, lol. If you looked carefully, you would see that I have a TM45. There are many of us who have proven this to be the most effective intake setup on and aftermarket carb. I don't know what you have been reading, or how you interperted it, but this gains more HP over the carb mount filter on everything but stock carb.
"We also seen the most power out of the DS snorkel over the on the carb filter. This was a surprise to me !!!" That was posted by The Bom. on page 2.
Old Feb 7, 2004 | 09:39 AM
  #107
THEBOM's Avatar
Originally posted by: OuterLimit
Where can I read more about the Pami 680cc kit?Thanks.
www.team-pami.com
They have the stuff.
Old Feb 7, 2004 | 03:53 PM
  #108
quadloco1's Avatar
Anybody experiment with a snorkel with twin carbs?
Old Feb 7, 2004 | 04:52 PM
  #109
BlackHawk's Avatar
I think you might need Scooby's engineering help to get a 'good' snorkel to work on dual carbs since you have to fabricate it yourself. He calculated the prefect length etc. for a snorkel type tube for his turbo. It seems to me you'ed really need to get exact with that sort of thing to REALLY see the results you want, if you just rig something up you could end up being a little off and not seeing the results that -could- be possible.
Old Feb 7, 2004 | 10:12 PM
  #110
busmechanic's Avatar
posted pics of my snorkle mount. similar to jerfinds.
