Reverse limiter
Old Feb 12, 2004 | 04:04 AM
natron1's Avatar
Default Reverse limiter
Finally got the new bomb traxter out for long hard ride here in the Laurel Highlands. The Trax was shaping up to be all I wanted in My new ATV. When I slided sideways in to a rut covered by drifted snow. The low floor boards got high centered. After alot of jousling around I started to get it to start out backwards in first and nailing the throttle. The reverse limiter kept kicking in and stalling the engin. I thought I read that this happens at 15 mph even though ofcourse the bomb was going slow. But still going. I also thought I read a post here for temporeally turning off the reverse limiter. Can that be done? I may someday in summer need get out of goo and need to temp. disable limiter again.
Also, just once and a while on turns of some speed (but not always) it would slide out from me. Could more experinced snow riders tell me if I should dial up the shocks or lower tire presure or both when snow riding. I should tell you I 300 lbs. Please no wise cracks about going on diet to cure problem please. Thankyou
Old Feb 12, 2004 | 09:21 AM
OregonDunePatrol's Avatar
Im not that familiar with the Traxter, but other quads with a reverse rev limiter are keyed off of the RPM on the CDI. There is no way I know of to modify an existing CDI to change the REV limit - Fwd or Rev.
Old Feb 12, 2004 | 09:51 AM
SANDMAN430's Avatar
one of my raptor friends grounded a wire.
Old Feb 12, 2004 | 10:51 PM
natron1's Avatar
Com on any more Ideas, maybe I can set the rpms higher in the CDI? Although I don't have a clue to what it is or how it works.
Old Feb 13, 2004 | 12:50 AM
Doctorturbo's Avatar
GOT BOOST!
Natron 1 I set up a switch in line with my reverse rev limiter. Need revs, flick switch and no limit backing up. The reverse/neutral lights flash so when done, flick switch again, shut down, start up and lights are off again. Down by the linkage side of the tranny there's some wires, run a switch in line with the purple/white wire, works great. Did this to the wife's machine today, no problems. No more backfiring, full power when you need it.
The credit goes to hoseclamp on this one, the Doctor just looked it up for you. Now you can race any ATV and beat them in reverse!!!!
Old Feb 13, 2004 | 12:57 AM
natron1's Avatar
Thankyou doctor, for the cure for a bad illness. I shall try it.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
