help with jettings and cdi
Old Mar 1, 2004 | 01:07 AM
cOoLdevil's Avatar
Default help with jettings and cdi
duneittilludie
so you have the big gun cdi so does it have a rev limiter or it does'nt have like the alba and RWR .
right now i have on my Ds the stock needle in the 4th clip and the main i think is 190 or 192 ( dynojet ) and im at sea level and i have the trinity full system stage IV
Old Mar 1, 2004 | 11:40 PM
duneittilludie's Avatar
cooldevil-Yes i have the big gun cdi and it does have a limit which i think is 1000 rpm above stock but whatever its limit is i know i dont hit it now .MisterHP-I am getting the billet end cap for my baja and your settings of (175 main-lid on-needle in 5th position-and 87 octane)are those compatible with running at sea level or from sea level to 1000 feet in elevation?I would also like to know how quick it is to change from the billet end cap back to the stock one?
Old Mar 2, 2004 | 01:11 AM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
Yea that works good at sea level to 2000ft with no problems. Switching end caps takes about 2 mins. Althought the new 04 bikes take a little longer because the canister seems to warp out of shape a little bit when the end cap is taken off. But it's not that big of a deal.
Old Mar 2, 2004 | 01:27 AM
MisterHP-Thanks for the feedback on the billet end cap it sounds like it will be a big improvement over the stock set up.
Old Mar 2, 2004 | 03:04 AM
  #15
cOoLdevil's Avatar
MisterHP
you sayed that the best setting is 175 main lid on needle in 5th do you mean stock needle or the dynojet needle
Old Mar 2, 2004 | 08:19 AM
  #16
sam's Avatar
sam
I think he means stock needle with mikuni jetting. also for some gains is to put some hose clamps around the intake boot to keep it from vibrating under exceleration. I took it one step further and wraped it with wire all the way up, you could do this to with hose clamps. see my picks if interested.
Sam
Old Mar 2, 2004 | 09:28 AM
  #17
Yes, stock needle with mikuni jetting.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
