What oil does everyone run?
Are you guys really still buying oil one quart at a time? There is no reason not buy a slightly larger container - there is NEVER going to be a sale price on it, it doesn't go bad from sitting around, you're never going to not need it... Save yourself $50 and buy it in a 5 gallon drum.
I think Maxima is considered semi specialty. You wont find the 5 gallon drum sitting on the floor at your local shop - you have to order it. You might even ask and have the guy at the counter tell you they don't exist. I've been told that, but I have one in my garage, so who was right? If you have trouble with getting a price etc, talk directly with the company that makes the Oil. Sounds like you're using Valvoline - they are a huge company, which could be good or bad when trying to contact them about this sort of thing. I know if you use -ANY- of the heavy duty diesel engine oils like Bartlett is using (Shell Rotella) then they only come in 1 gallon and larger containers. I'm considering moving to the heavy duty diesel engine out when my Maxima runs out, it'll probably cost half as much since they produce gigantic volumes of it.
#17
I Drag Race and My motor was built last year by Mr Horsepower...Piston, cam and ported. ..I used Red Line bought from Summit Racing the whole season, When he tore it down this year to change to the new piston , Tranny cut, new carb and new pipe....He told me it was one of the cleanest he'd seen......I made over 200 passes at Full Throtle.... I know what oil I'll be using this season....
#19
You can order by phone 1-800-230-3030 or on the net at summitracing.com....PART#
RED-11304 It is 10W-30 Syn...AT $6.45 a Quart... It just went down I paid $7.95 when I bought some for this season 2 weeks ago...go figure.......Get one of their catalogs it got GOOD Stuff...
