End cap
Old Mar 19, 2004 | 11:50 PM
  #21
busmechanic's Avatar
Default End cap
reinstalled the stock one. removing it without ruining it is the hardest part. I cut the two long straps at the end and dug it out from around the pipes at the base. had to cut about 1/4'' to a 1/2" off to clean the end back up. then just weld the straps back on the end. after you cut your pipes. looks stock and clean.
Old Mar 20, 2004 | 12:10 AM
  #22
satmike's Avatar
Default End cap
Sound easy enough, I'll give it a try this week end, it's a little to warm to ride!
