alky plug color
Old Mar 25, 2004 | 10:14 PM
POLARISFREAK's Avatar
Default alky plug color
WHat color should a ds on alky be for the plug. These are very black, is this lean? Also what should the plug gap be for alky? THanks
Old Mar 26, 2004 | 01:39 AM
marrtoo's Avatar
There probably black from when it was on gas or its burning oil. I would put new plugs in.
jmop [img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 26, 2004 | 01:51 AM
sandRappy's Avatar
I have always wondered this myself. I was running alkie for a little while but could never get it jetted right. I couldn't tell whether it was cutting out because it was lean or rich, and the plug color on mine was always white, no matter what I did with the jetting
Old Mar 26, 2004 | 01:55 AM
marrtoo's Avatar
I think its because alky doesnt carbon up like gas. Mine is always white too. Been told that the best way to know if jetted right was by the exhaust temp, at the header right out of the motor. Seems like it was biggerisbetter that posted that one time but not sure.
Old Mar 26, 2004 | 09:26 AM
Do you just run the stock plug gap?
Old Mar 26, 2004 | 10:35 AM
biggerisbetter's Avatar
Stock plug gap should be fine with a single carb.
bigger.
Old Mar 27, 2004 | 01:09 AM
MrMeaner's Avatar
I dont run a pilot and am curious about what main everyone else is running. I put a Pingel high flow pitcock on mine also. I just played with mine until It felt the best. Ive found that if you run too big a jet or drill it out or just dont run a main it makes your oil milky very fast. Also if you drill out a jet be careful they are easy to twist off. Ive done that. So tell me what mains are you guys running.
Old Mar 27, 2004 | 03:37 AM
XR650Warrior's Avatar
330 around here, but with a little elevation I don't run one at all.
Old Mar 27, 2004 | 03:41 AM
I've found that not running a pilot will tend to milk the oil more-so than no main
Old Mar 27, 2004 | 10:56 AM
MrMeaner's Avatar
What size pilot do you run XR
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Schneider
Jul 24, 2015 05:05 PM
Captjay
Jul 23, 2015 12:33 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
