Mr. Hp 46HV
Old Mar 28, 2004 | 07:47 PM
Entomber's Avatar
Default Mr. Hp 46HV
I want one.. if I can get my damn thumb throttle to push easier....
Old Mar 28, 2004 | 07:48 PM
JMAC650's Avatar
Default Mr. Hp 46HV
I can't wait to feel the difference. My MisterHP carb & ported intake is on the way[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 28, 2004 | 08:08 PM
BlackHawk's Avatar
Default Mr. Hp 46HV
My 46HV will be here on Tuesday or Wednesday - I've got the cable run & everything is ready for me to toss the carburetor in. The throttle pull as I have the cable run is easy enough the spring in the thumb throttle housing is almost strong enough to return it to zero position. I have a feeling with the spring from the 46HV it'll be a no brainer and throttle pull should be excellent.
Unfortunatly I wont be able to run my quad until perhaps the weekend of the 10th though. I heard BigBaja may be at Pismo that weekend, so it would be a cool time to be there - especially since he is going to be test running his new Mr. HP 720 plus a whole lotta stuff.
Entomber, where do you have the cable running? I have mine setup to run out the front, swings out to the left, then back to the right, then comes straight under the gas tank to the carburetor which has a 90 degree cable guide on it. If you need pics let me know, perhaps you should try routing your cable without the carb atached & check the pull before you re-hook up the carburetor.
Also be sure to run the fuel line up under the gas tank, I forget who's picture page on here showed how they re-routed the fuel line but it's important not to starve the carburetor of fuel! It may have been Sandaholic since I know he has a 46HV.
Old Mar 28, 2004 | 08:12 PM
buttfungus's Avatar
Default Mr. Hp 46HV
Old Mar 28, 2004 | 11:45 PM
  #15
busmechanic's Avatar
Default Mr. Hp 46HV
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 29, 2004 | 11:27 AM
  #16
CountryJoeGlass's Avatar
Default Mr. Hp 46HV
Old Mar 29, 2004 | 12:15 PM
  #17
biggerisbetter's Avatar
Default Mr. Hp 46HV
Thats some very impressive gains with just a carb swap.
Great job.
Bigger.
Old Mar 29, 2004 | 12:39 PM
  #18
DSengineer's Avatar
Has been here a long time!
Default Mr. Hp 46HV
BlackHawk,
Are you using the stock thumb throttle or the billet unit (no drilling required) that Mr HP is now recommending with the 46HV?
Old Mar 29, 2004 | 12:45 PM
  #19
BlackHawk's Avatar
Default Mr. Hp 46HV
DSengineer,
I have the billet thumb throttle all mounted & ready to go as soon as my Lectron gets here. If you look in my pictures link, you'll see a picture of the cable & throttle. I was really happy with the quality of the Moose billet throttle, it's such a simple design & looks great.
Old Mar 29, 2004 | 02:54 PM
  #20
1BigDSRider's Avatar
Default Mr. Hp 46HV
Great job.
Bigger.
I was a big gain over my previous setup. I was running rich with the stock carb.
I'm running the Moose Billet thumb throttle and its works nicely. Its a longer throw but not to bad.
