Stroke vs. Bore
Old Mar 29, 2004 | 10:28 PM
trailrider500's Avatar
Default Stroke vs. Bore
Strokers cant rev as high as a stock stroke, well they can but you will have holes in your case....
When stroked the wrist pin placement makes it harder on the piston skirt and is sometimes pushed into the oil ring which is only good for racing not riding every day..
Big bores rev slower and don't make the torque a stroker can..
Its best to have a good combination of bore and stroke..
I did many hours of research when i was thinking of boring and stroking my 289 in my stang..
Old Mar 30, 2004 | 01:46 AM
Doctorturbo's Avatar
GOT BOOST!
Sandaholic to answer your question. The longer rod you have the better angle you have on the hole. In other words, its straighter and less of an angle. You are correct, the stroke stays the same.
The more stroke you have, the more leverage you have. Think of it like a sprocket or gear advantage. Or better yet, ever try to arm wrestle a guy that has a 6" longer arm than you? You know what stroke can do for you then!!!!! Torque, torque, torque!!!!
Old Mar 30, 2004 | 12:38 PM
amd's Avatar
amd
doctor turbo nailed it right on the head...
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
