Am I rich or lean?
Old Apr 1, 2004 | 11:15 PM
Doctorturbo's Avatar
GOT BOOST!
Default Am I rich or lean?
skidoofan a couple of questions for ya.
1. Do you run pump gas or race gas?
2. When you say "just like it is bouncing off of the rev limiter", do you mean it feels like a miss?
Opps, I need one more. When did it start doing this? Right after you piped and filtered it? Or did it run good and just start running bad one day?
Old Apr 1, 2004 | 11:47 PM
skidoofan's Avatar
I run 91 octane gas. It started doing this after I installed the pipe. When your getting on the throttle its just like its running out of fuel it coughs and sputters from the mid on up through the top. I think I have to try a bigger main jet.
Old Apr 1, 2004 | 11:52 PM
thebigshow's Avatar
are you using mikuni jets or dyna jets?
Old Apr 1, 2004 | 11:55 PM
skidoofan's Avatar
mikuni
Old Apr 2, 2004 | 12:06 AM
  #15
thebigshow's Avatar
maybe its just me, but that jet sounds extremly high for a stock carb on gas. i ran dyna jets on my stock carb and it wasnt but 185, im not sure what size that is with mikuni jets, maybe around 165 im guessing...............when u did your plug check test did u run the bike at full throttle for a long distance and shut the motor off before u idled down?
Old Apr 2, 2004 | 12:54 AM
  #16
dunesled's Avatar
You are way to rich. Try bringing it back to 185 and just try it, you might be surprised.
Old Apr 2, 2004 | 12:56 AM
  #17
JMAC650's Avatar
If you are at sea level to 1000ft I would run a 172.5 mikuni main jet and stock needle in the fourth groove down from top. Cut 4 links off the slide spring. This will make a huge difference on throttle response. If you are running stock carb leave your airbox lid on. The response is much better. It sounds like you extremely rich on the top end.
Old Apr 2, 2004 | 09:08 AM
  #18
02BAJA's Avatar
I run a White Bros pipe witha carb mount filter and only run a 185. I think its just a hair on the rich side. I am at 400'+ elevation.
Old Apr 2, 2004 | 09:34 AM
  #19
skidoofan's Avatar
Thanks guys for all the help I am going to try and get a few different size jets this weekend and see what happens. Thanks again for all your help
Old Apr 2, 2004 | 11:29 AM
  #20
GOT BOOST!
And while your at the shop getting new jets, I would also buy a new plug or two, ..............or three. [img]i/expressions/face-icon-small-happy.gif[/img] Sounds like your DS will be healthy in no time. [img]i/expressions/face-icon-small-wink.gif[/img]
