Piston ?
Old Apr 5, 2004 | 01:48 PM
222's Avatar
222
Default Piston ?
My apologies - you are correct- it is only a 2% difference in piston weight, not 20%. You wouldn't be able to feel 2%.
I still don't understand the vibration thing with a lighter piston?
222
Old Apr 5, 2004 | 05:24 PM
Haulinonthedunes's Avatar
Default Piston ?
Originally posted by: 222
My apologies - you are correct- it is only a 2% difference in piston weight, not 20%. You wouldn't be able to feel 2%.I still don't understand the vibration thing with a lighter piston?222
Its alright man, I asked the this guy the same thing. I thought the lighter the piston the better off u are but he said no u dont want to light of piston because u will have alot of vibration. I probably wouldnt go any lighter than MR.HP's performence piston, because from what i have heard his a pretty light but good enough to where u wont have any problems. [img]i/expressions/face-icon-small-smile.gif[/img] Lance
Old Apr 5, 2004 | 06:05 PM
biggerisbetter's Avatar
Default Piston ?
Its probably not a good idea to hold a 14:1 compression engine at WOT for long periods of time(desert Racing). That is alot of strain on the bottom end. IMO you would be much happier with a 11:5 piston. You can change cams to put the power in the right rpm range for you.
Bigger.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
