pilot jet
Old May 5, 2004 | 04:39 PM
01ds650's Avatar
Default pilot jet
Just wondering how many guys with slight mods like mine. (HMF slip-on, 185 Dynojet, dynojet needle 3rd notch, RWR CDI and K&N lid on) Have the stock pilot jet? I have my air screw turned 2 3/4 out. My local Bomb mechanic did my valve shim change & said that it seemed lean on the bottom & suggested maybe a bigger pilot jet. I never noticed too many guys messing with that so I thought I'd ask if anyone had changed that. Does anyone know the stock size for sure and/or any recommendations on a size to try?
Thanks
Old May 5, 2004 | 06:21 PM
Oldmanracing's Avatar
Default pilot jet
The factory was using a .o40 until late 2001, then went to a .045
Most have gone with your mods to a .0475 Pilot screw out 3 turns
I run a .050 because of having advanced timing.
Old May 5, 2004 | 06:24 PM
Hightower's Avatar
Default pilot jet
my '01 was lean on the pilot too, had a 40, I upped it to 45 and all as better
Old May 5, 2004 | 06:35 PM
01ds650's Avatar
Default pilot jet
Thanks guys.
40, 45 guns or pilot jets....?
Old May 5, 2004 | 07:41 PM
Hightower's Avatar
Default pilot jet
also make sure when you change the pilot, you pick the right one. its the long skinny one, not the starte jet that looks just like the main jet. its in the 40 range too....
many a people have replaced the starter jet in place of the main jet actually, because they look the same, going from a 40 to a 180 makes for some problems!
Old May 5, 2004 | 09:47 PM
01ds650's Avatar
Default pilot jet
Will do.
40, 180 what's the difference....
Old May 20, 2004 | 08:21 PM
01ds650's Avatar
Default pilot jet
Just ordered a 45. They said it went 45, then 50. Where did you guys fins a 475 at?
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Aitch
Jul 21, 2015 09:40 PM
