CC's Bore and stroke on: Stock vs. 680 vs. 703 vs. 720 vs. 727 vs. 730 vs. 733 vs.760 vs. 770 vs. 800 vs. 830
Old Sep 28, 2004 | 12:38 PM
DuneMe's Avatar
Default CC's Bore and stroke on: Stock vs. 680 vs. 703 vs. 720 vs. 727 vs. 730 vs. 733 vs.760 vs. 770 vs. 800 vs. 830
Bump.
Time to revise the offerings [img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 28, 2004 | 04:20 PM
Sandaholic's Avatar
The bom posted a while back that Pami now has a 105.5 big bore cylinder that does not require case machine work, but the head does require work. Its supposed to be a "wet sleeve."
MisterHP has not released their 105.5 cylinder yet, so no update from them.
TVI still has the same kit with the steel sleeved cylinder.
Old Sep 28, 2004 | 04:28 PM
ds650king's Avatar
Old Sep 28, 2004 | 04:29 PM
ds650king's Avatar
duneme, i think that your original calculations were incorrect for
10.55 10.55 8.7 .787 770.8 +5.5mm bore & +5mm stroke TVI 770???
You say that the tvi is a 5mm stroke but you only put in 8.7 which should be 8.8.
Also I believe the bore on the tvi is 104.7 at least thats what I've heard about the 720 kits, maybe they do a different bore for the 770s
Does that first part sound right?
kyle
Old Sep 28, 2004 | 05:02 PM
  #15
DuneMe's Avatar
Looks like Falicon is doing the same thing Pami is doing Falicon's welded sleeved cylinder for the YFZ
Mr. HP's cylinder is the same as Pami's (105.5 piston).
DS650King - yeh, I didn't know the TVI dimensions. I'm sure you're right.
Old Sep 28, 2004 | 05:12 PM
  #16
ds650king's Avatar
so what your saying isthat the mrhp cylinder is the same exact thing as the pami one?
Old Jun 11, 2006 | 06:16 PM
  #17
choosetolose04's Avatar
Very good info.....[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 12, 2006 | 12:22 PM
  #18
1BigDSRider's Avatar
Choose, did you blow a head gasket last night?? Looks like you pulled half of the big bore threads up last night.
Old Jun 12, 2006 | 12:25 PM
  #19
No head gasket malfunction...just weighing my options...[img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 27, 2006 | 11:36 PM
  #20
shmee's Avatar
SO, 105.5 is 730cc? right?
then WHATS 105.2?? 725?
