ds blowing a little smoke at high rpms...
Old May 22, 2004 | 08:24 PM
dondiesel444's Avatar
Default ds blowing a little smoke at high rpms...
I have been practicing my wheelies, and sometimes at the end of a wheelie I will really rev the engine to try and keep the frontend up. then whe I finally come down and let off the throttle I can see a little cloud of blue smoke out the exhaust.
could this be a problem, or just b/c I am reving it too high??
thanks.
Old May 22, 2004 | 09:10 PM
thebigshow's Avatar
if u dont have an after market ignition box,....then no i dont think u can rev it to high, the rev limiter will stop u before u can get to high to hurt the engine.
Old May 22, 2004 | 09:26 PM
I know I'm not over-reving it, maybe it's b/c of the angle of the atv when I'm doin a wheelie?????
yamahawarriormods's Avatar
yeh like big show said you will hit the rev limiter but on the other hand you might need new rings or valve seals in the future
Old May 23, 2004 | 10:24 AM
amd's Avatar
amd
If it only does it when you let off it is more then likely valve guides. It is pulling oil through the guide and burning it. New seals might help for a little while, but it is going to need guides before long.
Old May 23, 2004 | 12:16 PM
now the scary question, how much will something like that cost?
Old May 23, 2004 | 12:46 PM
amd's Avatar
amd
It depends on who you have do it, guides themselves arent that much, it will depend on how much they charge you for labor. It shouldnt be more then 150 at the most.
2quiker
Mar 22, 2022 08:36 PM
bvolks
Sep 13, 2015 12:57 PM
Hw00d
Sep 10, 2015 08:53 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
