More Power
Old May 27, 2004 | 07:35 PM
buhjuh16's Avatar
Default More Power
alright, what is a mod quad end cap and also a procom CDI? Also, how would you jet to 172.5 main, and clip on bottom slot of needle? Sorry if it sounds ignorant, but I dont know much about the engine or performance, i just know about riding it. and if i cut off 4 coils off the front springs, that will lower the front end wont it? If it does, then wouldnt i need to do the same to the rear to make the ds level? yesterday i jumped a tabletop about 25 ft. long and got about 6 ft high and it bottomed out when i landed. wouldnt it be worse if i cut the coils?
Old May 27, 2004 | 07:53 PM
TheChosenOne's Avatar
Default More Power
The main is inside the float bowel, 4 phillips screws hold it on. And no.... bad.... Don't cut springs off the shocks. They are talking about the slide spring inside the carb. If you take off your seat there is a gold coloured cap with 2 screws. Then when u get that off, there is a spring. Under the diaphram there is the slide, and the needle. Search a thread entitled "jetting specs" thats my old one and bartlettracing did an awsome job explaning it all, as did a few others. Hope this helps.
Old May 28, 2004 | 01:45 AM
buhjuh16's Avatar
Default More Power
alright so there is the:
- 15 t front sproket from rocky mountain atv
- mod quad end cap - where do i get this at?
- procom CDI - ebay
- jet to 172.5 by cutting 4 coils off the carb slide spring
- stiffer clutch springs - does rocky mountain atv have these also?
Old May 28, 2004 | 02:24 AM
JMAC650's Avatar
Default More Power
- procom CDI - ebay
15t front sprocket
end cap
procom cdi
K&N air filter
172.5 main jet
cut 4 coils off carb slide spring
60% ron woods clutch springs(good idea)
You should be ready to tear it up
[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 28, 2004 | 02:39 AM
  #15
MTX's Avatar
MTX
Default More Power
www.on-dunes.com has alot of ds mods, most of what you have listed . I was wondering should i get 30% clutch or 60, i all dune ride, and some times drag.
Old May 28, 2004 | 09:14 AM
  #16
BajaIowa's Avatar
Default More Power
If you hurry there is a mod quad endcap on ebay now here. You can also get one at on-dunes. It will be the cheapest hp gain you can get. There are jetting specs at the bottom of the page. I agree with the 15 tooth, but I would spend the money and buy a service manual from your dealer, or a cd version off of ebay. This way you can see how the carb works and fix your own stuff on the machine.
Justin
Old May 28, 2004 | 10:29 AM
  #17
SANDMAN430's Avatar
Default More Power
i really liked the springs for dune riding. those changes sam listed did me very well for a long time. didn't mr hp show where the spring cutting wasn't any good? well if he didn't i was watching that mod with other ds's around me and i didn't see any race differences, but then again it is hard for such a small mod to make a big diffence. i did the 17 first then the 15, and i feel unless you are a desert racer the 17 is to tall you'll use all that top speed very seldom, if at all. and in the dunes a stock machine will have a problem pulling the topend due to drag.
Old May 28, 2004 | 12:33 PM
  #18
buhjuh16's Avatar
Default More Power
there are no dunes arond here that i know of, so all of my riding is either in the 1/8 or 1/4 mile and on trails. also, can someone point me in the direction of a thread abot jetting to 172.5. or is that done by cutting the 4 coils off the spring ?
Old May 28, 2004 | 12:51 PM
  #19
JMAC650's Avatar
Default More Power
Cutting 4 coils is done on the top of the carb, just remove the gold colored cap and the spring is right there. Changing the main jet is done from the bottom of the carb, remove the bowl and the main jet is the one that hangs the lowest and has a 165 on it.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
