more powerful than a DS?
Originally posted by: Andrew Thomas
I know you can get a Cummins in a F450 or F550 medium duty truck. (why would you though since I think they offer a 7.2L Cat). But I'm positive that F250 & F350 are IH only. I'm pretty sure because at work we make parts for them.
k. thnx bye.
Do you know what tranny & Tcase he ran? I didn't even know that could be accomplished. At least not for a reasonable price...
Is that Duramax an 02? That's the best looking year.
For the Ford fans....PowerJoke ?
Sorry, I can't find a Duracrax vid... [img]i/expressions/face-icon-small-wink.gif[/img]
#15
I saw that F350 run in Phoenix at Firebird Raceway, its a green '95 F350,crew cab, long bed 4x4. I even got to check out under the hood- 2 HUGE polished ball bearing turbos on both sides of a totally polished, chromed 12 valve cummins.
I think the guy is known as "Maddog".
#16
Originally posted by: AZVFORCE
I saw that F350 run in Phoenix at Firebird Raceway, its a green '95 F350,crew cab, long bed 4x4. I even got to check out under the hood- 2 HUGE polished ball bearing turbos on both sides of a totally polished, chromed 12 valve cummins.I think the guy is known as "Maddog".
#17
#18
Yes, that is a Ford and Yes it does have a 12-valve cummins in it. He's got about 25g's into the motor and unknown amounts into the tranny. I believe that the Trans is a ATS-MADE Dodge auto. ATS sponsors the truck. VERY impressive! Have the video at home to cue up on demand.
BigDaddy
BigDaddy
#19
The only Ford you can get a Cummins in is the F650 Which is a heavy hauler type truck not a light duty. The F450 and F550 are chassis cabs versions with heavier equipment than the the common 250 and 350. The only difference between a F350 and a 250 is the 350 has a 4" block under the back springs instead of a 2" block found on the F250 and it comes with a sway bar as standerd equip where it is a option on the 250. The only diesel motor available in the light duty trucks is the 6.0L Powerstroke IH mated to either the torque shift auto(proving itself to be one of the best EVER) or to the 6 speed manual.
#20
