another dumb oil light question?
Old Jun 16, 2004 | 09:49 PM
SPARKY4Q2's Avatar
Default another dumb oil light question?
i was riding in a rock quarry , temp was around 90, and after riding for a hour or so my light would come on at low idle, rev it up a little and it would go away. my fan was running, oil is full, actully just changed it a week before with mobil 1 10-40 mtx full syn. anybody know what this is?[img]i/expressions/face-icon-small-frown.gif[/img]
Old Jun 16, 2004 | 09:55 PM
busmechanic's Avatar
sensor is probably going out of range. I screwed a pressure gauge with 1/8" fitting directly in the sensor port to verify. mine lasted 2 years. ditched it, and went to a mechanical gauge.
Old Jun 16, 2004 | 10:03 PM
SPARKY4Q2's Avatar
sounds like a good investment! i'll put one on order tonight! thanks agian!!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 16, 2004 | 10:05 PM
ScoobyDFW's Avatar
I've found with an oil pressure gauge that any oil with a viscosity of 100 cSt or less at 40C will result in low oil pressure. I run the V-TWIN oil with 130 cSt spec and the pressure is normal. When I ran another oil with 100 cSt spec the pressure was very very low.
mobil oil specs
Old Jun 16, 2004 | 10:08 PM
SPARKY4Q2's Avatar
oh by the way, what do you do with the sensor wire? wont the light come on if its unplugged? or do you plum it in with the gauge?
Old Jun 16, 2004 | 10:16 PM
ScoobyDFW's Avatar
If you disconnect the sensor it doesn't drive the red light on; coolant overtemp still works fine. You can also tee the 1/8" NPT port.
I wouldn't run the MX4T oil (if that's what you have). The viscosity is way too low.
SPARKY4Q2's Avatar
Scobby- that was kinda forein to me?? you seem to know a lot about oil! so are you saying i should use the v-twin oil instead?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 16, 2004 | 10:23 PM
ScoobyDFW's Avatar
Every oil is rated for it's resistance to flow at a given temperature (viscosity).
What I'm saying is from my experience, when I had oil with a similar rating as yours the oil "turned to water" at temperature which causes the pressure to drop (pressure is created by resistance to flow).
I'm saying all DS owners should check the viscosity spec of the oil they use. I don't recommend anyone use an oil with a viscosity spec of 100 cSt or less.
The V-TWIN oil is greater then 100cSt as are many others.
Old Jun 16, 2004 | 10:34 PM
SPARKY4Q2's Avatar
THANKS AGIAN SCOOBY! Ill switch to the v-twin oil, i prefer mobil 1 anyway, so i will stick with it, thats what you were talking about was the mobil 1 v-twin right? what weight is that?
Old Jun 17, 2004 | 07:26 AM
ScoobyDFW's Avatar
mobil 1 20W50 V-TWIN full synthetic at some walmart's (cheapest) and at autozone.
there are also 10W40 oils that have higher viscosity spec than 100 cSt.
Kyle5050
Dec 13, 2019 04:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
kodiak450.
Utility ATVs
13
Jul 27, 2015 05:07 PM
DeFox500
Jul 26, 2015 06:32 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
