modded ds not much faster than stocker?
Old Jul 4, 2004 | 03:04 PM
DuneMe's Avatar
Default modded ds not much faster than stocker?
I don't know if I really saw gains with the TM45 when I went with it.
Go with an 11:1 piston and a set of cams and you won't believe the power. Yeh, you'll probably want a different carb then but, carbs are expensive and I don't think you will see the gains you will $ for $ than you will on a piston and cams.
Start by pulling the valve cover. Check your valve clearances. That is a very minor thing to do and you won't get into any trouble by just pulling the valve cover.
Old Jul 4, 2004 | 03:09 PM
R00ST's Avatar
if you check out this thread, its where i posted about my starter crunching problem... seems it is one of two things, one way bearing, or the cam tensioner. If cam tensioner is up under the valve cover i could knock out two birds with one wrench and check clearances and replace/adjust cam chain tensioner.
Starter problem
o, and sandman i did replace the MBRP's with the stockers (dont know if it made too much of a difference but im gonna leave them off for now)
*** link isnt working for me.... *** if it dosnt work you can copy/paste it
http://65.54.170.250/cgi-bin/linkrd?...eadid%3d408787
Old Jul 4, 2004 | 05:11 PM
DuneMe's Avatar
Cam chain tensioner is on the cylinder below the carb on the left side of the bike. Check On Dunes - I think they have a manual chain tensioner that you may want to go to.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
