Help, my DS pulls to the right.
Old Jul 6, 2004 | 12:41 AM
BajaXRider04's Avatar
Default Help, my DS pulls to the right.
Hello all,
Since I have put on the new 22 razr 2's on the rear, the 15t front gear and adjusted the chain tension I notice that my quad pulls to the right.
Even when Im up on two wheels ridding a wheelie it pulls to the right. If I let of the gas it doesnt pull to bad but the moment I pin the gas it pulls hard to the right. What could it be? Could I have adjusted the chain wrong or put the front gear on wrong to cause this? Tire pressure is all equal on both sides. Or could it be just because I now have bias rear tires instead of the radials?
Please help thanks.
Old Jul 6, 2004 | 01:22 AM
JMAC650's Avatar
Sounds like the left tire is bigger than the right. I had this problem with my old Pure Sport Bandits. That is why i switched to Holeshots. Just measure around the tire in the center of the tread all the way around.
Old Jul 6, 2004 | 01:33 AM
thanks i will give that a try tomarrow. wow if that is it i sure will be pissed.
The razr 2 cost me a fortune. I wonder if that would be a warranty issue?
Old Jul 6, 2004 | 02:04 AM
JMAC650's Avatar
They should. The problem is if one is bigger than the other how do you know which one to send back?
Old Jul 6, 2004 | 02:05 AM
JMAC650's Avatar
Also when you measure them make sure they both have the same air pressure.
Old Jul 6, 2004 | 03:10 AM
WISTECH's Avatar
I have a set of the standard holeshots with the same problem. It takes 1 pound of pressure difference to even them up.
As far as the pulling problem ,check the rear axle bearings and swingarm pivot bearings. Many times one side will fail and give these symptoms.
Old Jul 11, 2004 | 01:11 AM
I got it pulling straight. It was all in the air pressure, I had to adjust one lb higher on one side.
mattcraig1
12
Aug 27, 2015 12:23 PM
panicmanic
Aug 25, 2015 09:10 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Polarisman1123
Aug 3, 2015 02:08 PM
ScopeZ_
Jul 28, 2015 01:44 AM
