What type of LOCTITE ?
Old Jul 18, 2004 | 04:11 AM
rescuediver's Avatar
Default What type of LOCTITE ?
Thanks busmechanic, I learned something new today. And it was right here on the forum[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 18, 2004 | 12:01 PM
BigWaynester's Avatar
The flywheel nut has 130-150 ft.lbs.spec. I thought I may need something stronger than blue.
Old Jul 18, 2004 | 01:00 PM
86250rrider's Avatar
nah.....blue is you ,good $hi+! dont use red on anything with fine threads(please)
Old Jul 18, 2004 | 01:55 PM
Hightower's Avatar
Ditto busmechanic.
you can't go by color alone, there are several blues, several reds, several greens, etc. and there are several of each for various temperature usages. the high temp loctite I have for exhaust studs is green for example, but there is also a green that is not for high temps. the material its screwing into is also a factor - you don't want to use a strong permanent loctite on very fine threads, or aluminum threads. this is why the shop manual calls for a particualr blue loctite on the two 6mm bolts on the cam chain guide, a particular red in lots of other places, and a particular green on the cam sprockets.
the best thing to do is go by the recomendation in the shop manual - it tells you exactly what loctite # to use where. this way you know it can handle the temp and is the right choice for the application. there is serious science behind loctite, but its often overlooked. be certain you clean the threads of the bolt and what it scews into. loctite even makes a primer, and this primer is needed for the ultimate strength they claim, without the primer the strength is not quite what its supposed to be. but I use elctrical contact cleaner because the primer is hard to find since the stores don't know jack.
Old Jul 18, 2004 | 04:09 PM
  #15
busmechanic's Avatar
hightower,I had the exact same thought after I posted. use what the shop manual specifies!
Old Jul 18, 2004 | 06:09 PM
  #16
bomar76's Avatar
Bomb Service manual shows Loctite #243 ..... from the Loctite website:
243 Threadlocker Oil Resistant/Medium Strength
A general purpose, medium strength threadlocker with improved oil tolerance. For fasteners between 1/4" and 3/4" (6 to 20 mm) diameters.
Typical Applications
Machine tools, presses, pumps, compressors, mounting bolts, gearboxes.
Approvals/Specifications
NSF/ANSI 61
Old Jul 19, 2004 | 12:34 AM
  #17
Thanks for for all the info on Loctite. Never knew there was so much technical information on it[img]i/expressions/face-icon-small-smile.gif[/img]
Johnny Mac
60
Dec 14, 2019 06:13 PM
Sassinm1
Sep 30, 2015 04:23 AM
Hack714
Sep 26, 2015 08:11 AM
