What type of anti-freeze?
Old Aug 2, 2004 | 04:54 PM
THeBYRD's Avatar
Default What type of anti-freeze?
Do you guys use a cretian type of anti-freeze or is there a certian type i should use?
Old Aug 2, 2004 | 05:03 PM
shmee's Avatar
reg green stuff.
Old Aug 2, 2004 | 05:06 PM
shmee's Avatar
ps if you go to your local gm dealership they have coolant system sealent tabs, smash one tab and put it in there, it will help the aluminum from corosion " i think i spelled that right" plus is will stop any leaks in the gasket.
Old Aug 2, 2004 | 05:54 PM
PUSHINTHELIMIT's Avatar
Right on! I used those GM seal tabs for as long as I owned my DS. You wont get any better for a radiator sealer and it wont plug up the whole cooling system either.
Old Aug 2, 2004 | 05:57 PM
rldbobcat's Avatar
If you ride the dunes you might look into Purple Ice Coolant, it will reduce your engine temps drastically.
Old Aug 2, 2004 | 08:24 PM
Air's Avatar
Air
I use Engine Ice.
Old Aug 2, 2004 | 08:56 PM
DSaholic's Avatar
Engine ice for me too. It seems to help the temps a bit. It also comes pre-mixed 50/50.
Old Aug 2, 2004 | 09:46 PM
1BigDSRider's Avatar
Engine Ice here.
Old Aug 3, 2004 | 01:42 AM
THeBYRD's Avatar
So would it be if i run car anti freeze?
Old Aug 3, 2004 | 03:16 AM
BlackHawk's Avatar
I run engine ice as well, it works great. The coolant in the DS is normal 'car' anti freeze, nothing special. Just be sure it is Ethelyene Glycol and labeled to be OK for aluminum radiators. The engine ice just helps keep the engine a little cooler - meaning the fan comes on less etc.
Johnny Mac
60
Dec 14, 2019 06:13 PM
Sassinm1
Sep 30, 2015 04:23 AM
Hack714
Sep 26, 2015 08:11 AM
