NOS?????
Old Aug 23, 2004 | 12:52 AM
HARD1's Avatar
Default NOS?????
Doctor turbo, are you using gravity flow for you fuel???? I see that you are not listing an auxillary fuel pump? Please explain you set-up.
Old Aug 23, 2004 | 12:57 AM
Doctorturbo's Avatar
GOT BOOST!
Default NOS?????
OOPS......knew I forgot something!!! Thanks for the reminder.
A good filter would not hurt either.
Old Aug 23, 2004 | 12:34 PM
HARD1's Avatar
Default NOS?????
I also recommend a bottle heater.
Old Aug 23, 2004 | 12:42 PM
SANDMAN430's Avatar
Default NOS?????
you don't have to have it but there is a fuel pressure switch that if you lose fuel pressure will shut the system down.
Old Aug 23, 2004 | 02:11 PM
  #15
amd's Avatar
amd
Default NOS?????
Yea the hobbs switch is the fuel pressure switch. I have always hated them they are very unreliable some more then other. The first one I used was the best and never give me any probs, But a few other I have used all give me problems. Nothing more aggravating then trying to spray it and it not working because the hobbs switch is inacurate and has changed adjustment. Some people swear buy them, it is all a matter of opinion. Bottle heater is good to have on cool days when it isn't warm enough to maintain good bottle psi.
Old Aug 23, 2004 | 04:19 PM
  #16
dabomb03's Avatar
Default NOS?????
u guys running nos don't have stock internal engine parts do you? like u have a different piston and stuff right? cause i kno with cars and stuff nos will burn up stock parts same goes for the bomb right?
Old Aug 23, 2004 | 04:57 PM
  #17
mean650's Avatar
Default NOS?????
jwalk1,
i have a new ron wood/nos with fuel pump.e-mail me,masters066@aol.com.also have plenty of other stuff.motorstage 2(50 hrs on it),tranny,45carb&intake,cdi.and the nos.motor is on alcohol right now,never been sprayed with nos.just alcohol...will run 13.90 at the drag strip
Old Aug 23, 2004 | 05:13 PM
  #18
amd's Avatar
amd
Default NOS?????
All my internals are stock. Depends on how much you are wanting to spray it, stock internals will do just fine with lower shots. The most I run is a 20 shot. Nitrous isn't hard on parts, a properly intalled and tuned system with normal shots will last just as long as if it didnt have nitrous. Nitrous couldnt be any easier on a single cylinder motor.
Old Aug 23, 2004 | 05:14 PM
  #19
HARD1's Avatar
Default NOS?????
You can run NOS on a completely stock motor. I am running a system on a 04 Baja that is completely stock. Like everything you need to use it in moderation on a stock motor, You will get in trouble the higher you go on NOS. You can run a 15hp shot and not have any problems....... And I haven't seen any problems going a little higher but you just increase your chances.........
Old Sep 2, 2004 | 02:31 AM
  #20
HARD1's Avatar
Default NOS?????
I finally had a chance to get some pictures up of one of my NOS installs. The solonoids are mounted under the gas tank cover tucked out of the way and the fuel pump is located in the air box.
