rear swing arm, stink!
The front bolt on the swing arm of my warrior will not come out. *the one closest to the engine* It's like frozen in there, and i was wondering if any one had any idea of getting it out.... I heard about the same problem with the 400ex's...... Please help ASAP as i'm trying to fix it now.
the nut is off.. i just need to get the bolt out it's so lose i can use my fingers to losen it.
thanks...
thanks...
Sounds like its seized in the inner races of the bearings
I asume it is a hollow pin if it is get a series of drills and drill it out.
Its not as much hassel as it sounds. and the easiest solution to your problem asuming you have already tried penatrating oil and a brass dolly
