Hmmm.....14 tooth, or 15 tooth ft sprocket....
Old Sep 15, 2004 | 02:00 PM
Freakneh's Avatar
Default Hmmm.....14 tooth, or 15 tooth ft sprocket....
That's definately a concern... I'm going to install a kill switch before I go too... My main reason for going to a lower sprocket was because of my weight, plus the paddles, as they are pretty heavy. My Banshee wouldn't pull me up Olds, etc in 4th until I regeared... I figured I'd be proactive and take care of it on the DS before I left....
Old Sep 15, 2004 | 03:54 PM
JEFFROE's Avatar
sorry don't mean to be a spoiler but i rather run a 14 up front in the sand on my stocker or 760!! 2nd gear starts for racing and a low first gear for getting the paddles spinning when climbing. with 5 gears, top speed isn't usually an issue and the paddles suck up power like crazy. my 2 cents[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 15, 2004 | 07:06 PM
Freakneh's Avatar
LOL...there's one in every bunch...[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 15, 2004 | 08:28 PM
Freakneh's Avatar
JEFFROE, MrMeaner mentioned possible over rev with a 15 tooth and 20" tires...have you ever encountered this with a 14 tooth, that your aware of? Are you running a 20" paddle tire? I'm really not too concerned with overall top speed, since the paddles, and sand would definately drop it considerably with a stock countershaft sprocket anyway...
I think I'll take the advice of buying a 15 tooth, and then put it on if necessary.
Thanks again,
Justin
Old Sep 15, 2004 | 09:25 PM
  #15
Yardbird's Avatar
With your mods I would leave the stock sprocket on. If you're into draggin up Olds then even with the 14T on the front you still might not be able to pull 4th gear up it. Plus you would have to shift twice going through the whoops and up the hill if you start in 2nd. I dropped down to a 15T once and didn't like it. Second gear starts weren't a problem either with the stock sprocket. Third gear wasn't tall enough and the barely modded YFZ's were just a little faster when we were dead even going through the whoops but they would slowly gain on me up the hill. I still had plenty of power but was topping out in third and fourth was too much. I've got basically the same mods as you minus the CDI. I wasn't hitting my rev limiter either so that wasn't a factor. But hey you can always swap the sprocket really quick if you aren't getting the results you want. Just bring them with when you go to the dunes.
Old Sep 15, 2004 | 10:03 PM
  #16
Freakneh's Avatar
Yup, since it's such an easy swap, I'm just going to pick one up....they're super cheap thru RMATV.
Old Sep 15, 2004 | 10:39 PM
  #17
OregonDunePatrol's Avatar
Make that two! I ran a 14/40 combination for years with a Ron Wood Racing CDI and his stage II mods - Not a bad set up.
Old Sep 15, 2004 | 11:14 PM
  #18
lilnotts's Avatar
lol wow sand really sucks up the power, i run 16/40 with my 22" excavators and those aren't light non-agressive tires
Old Sep 16, 2004 | 01:36 AM
  #19
Freakneh's Avatar
I just remembered...I'll actually be running 22" Holeshots in a week or two...so I might just switch over to the 15, and then take the stock sprocket with me when I go to Glamis....that settles that....[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 16, 2004 | 10:23 AM
  #20
shmee's Avatar
im also running a 14/40 gearing.
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
MoRacer
Aug 27, 2000 12:56 AM
THEXOTIC1
Jun 23, 2000 05:02 PM
bigmanm
Mar 19, 2000 01:37 AM
