old topic, FAN DIED!
Old Sep 27, 2004 | 08:56 PM
SPARKY4Q2's Avatar
Default old topic, FAN DIED!
I did some riding over the weekend, my idiot light came on, so i stopped and noticed my fan was running, but very slow. Kinda making a grinding noise? I dont know if the brushes are bad, bearings maybe? I let it idle in the garage till the light came on, and the fan did not come on, i turned it a little by hand and it took off, but still the same thing, very slow and dont sound healthy. I remember somebody saying where you could get one for a reasonable price. Has anybody checked in to any different styles of fans, the stock one dont seem very dependable, alot of people seem to have problems with them! Any help is greatly appreciatted! THANKS GUYS!!!![img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 27, 2004 | 09:37 PM
SPARKY4Q2's Avatar
Anybody?
Old Sep 27, 2004 | 10:13 PM
1BigDSRider's Avatar
You can pick one up for around 60 at Offroadwarehouse. Do a search for old post about the fan and you will find all the info you need.
Old Sep 27, 2004 | 10:43 PM
Hightower's Avatar
Its a SPAL electric PULL fan 6.5" diameter
available at Offroadwarehouse.com for $71.99
6.5 electric pull fan at Offroadwarehouse.com
order it online and you'll have it in 3 days, I just installed one yesterday [img]i/expressions/face-icon-small-sad.gif[/img]
Old Sep 28, 2004 | 02:43 AM
BlackHawk's Avatar
I highly suggesr re-mounting the fan in the same fashion as the 2002 and newer DSs or perhaps if you can find another good way to mount it.
Old Sep 28, 2004 | 04:13 AM
Hightower's Avatar
I agree, too bad the dealers don't offer a conversion kit.
there is room between the radiator and frame to actually screw mounting tabs on to bolt the fan with rubber grommets, using countersunk screw heads. this would necesitate radiator removal to drill and stuff, but doesn't look to be too hard. of course welding tabs would be ideal, but for those that can't, or don't wanna have to repaint I mean.
I'm gonna take this on over the winter, and if it works out simple post pics of the process for everybody to take adantage of.
Old Sep 28, 2004 | 05:38 PM
SPARKY4Q2's Avatar
thanks for all the info guys!! mine is a 2003 baja, will that fan fit in the sock location?
Old Sep 29, 2004 | 04:55 AM
BlackHawk's Avatar
Hightower,
If you come up with something good let me know, I'd love to put that on my site. This is probably the most important 'mod' someone could make to a 2000 - 2001 machine, aside from the 2000 models using the larger filter cover - nothing will ever top that.
SPARKY4Q2,
If you have a 2003 Baja (same as me) then your fan already has the better mounting location and it is probably more of a fluke than anything that it failed - I'd just replace it and you probably wont ever think about it again.
Old Sep 29, 2004 | 10:22 AM
CountryJoeGlass's Avatar
[quote]
Originally posted by: BlackHawk
Hightower,
BlackHawk can you fill me in on the larger filter cover?
Old Sep 29, 2004 | 01:05 PM
BlackHawk's Avatar
Country Joe,
Just buy the oil filter cover from a 2001 or newer DS650, when you do your next oil change buy the filter for a 2001 DS and leave your 2000 filter cover off, install the longer filter, the longer filter cover and that is about it, do everything else exactly the same as before - now you have the newer filter style.
