free hp from mr hp?
free hp from mr hp?
Originally posted by: DCryder
fine with 87 as long as it is tuned right because it is borderline and if ran lean could be dangerous to your engine.
free hp from mr hp?
jackass, (no insult intended)
when you simply change the gas from 91 octane, to 87 octane that is the timing advance. 87 octane gas burns at a lower temperature, and therfore will ignight sooner than the 91 which Bombardier recomends. There is no mechanical way to advance timing - the only other way to advance timing is to buy a CDI box with advanced timing.
On my 2001 DS650 I am running with 4 coils cut off the spring, jetted correctly, 87 octane gas and the air system in stock configuration except for the snorkel tubes are run outside of the frame. The engine runs very well for a stock engine. Oh and I also had my intake ported by Mr. HP as well. Basically if you add two HP here, and two HP there, it turns into a good amount when you are all said and done. The end result being a machine that runs very strong and will make you happy.
Concerning the needle in the 5th (lowest) clip position - I couldn't run it this way on either of my DS650s as they both coughed and choaked too much, so I'd try the 5th position and see what happens. Good thing the DS is so easy to re-jet in stock trim!
#15
free hp from mr hp?
lol ok thanks, that was my cb handle when i drove semi over the road lol i would walk into a truck stop and if i knew a waitress she wouls say hey jackass and everyone in the place would turn around lol, dcryder said not to cut the coils in a 2002 or newer bike cause the spring is already shorter, im gonna check my jetting tomorrow if it stop raining lol, first with the main and then with the idle scew then with the needle ill let ya know how it turns out, if you have any suggestions i can always use some good ones thanks man
#16
free hp from mr hp?
I cut the spring in both my 2001 and 2003, the springs were slightly different, but the same height. I have two extra springs I paid $5 each for. I'd cut the spring - the worst that will happen is you'll need a new spring. If you are nervous, send me $5 through paypal or something and I'll send you a spring so you can go back to stock. Or hell, cut the spring I mail to you. (Or get it from the dealer and do the same thing.)
#17
Lou Domenech
09-11-2015 06:35 PM
TheATVSuperStore.com
TheATVSuperStore
09-09-2015 07:43 PM
