Battery Charger??
Old Oct 15, 2004 | 07:56 AM
raidermike67's Avatar
Default Battery Charger??
I've had a couple of batteries run dead on me in my quads and dirtbike, is there any harm in recharging via a normal battery charger? I have to get a trickle charger but I'm curious if it will cause any problems in a pinch?
Old Oct 15, 2004 | 10:59 AM
busmechanic's Avatar
not really any harm in it to speak of. it may shorten the battery life in the long run. just set your charger on the lowest amp rating that it has. and get a tender asap.
Old Oct 15, 2004 | 11:09 AM
Prozack's Avatar
be carefull tho.... Even at the lowest setting they tend to boil pretty easy and will loose water. make sure they are full before you charge them to save yourself the agony of trashing your battery.
Old Oct 19, 2004 | 04:14 PM
AZDUNNER's Avatar
You'll want to charge them at no more than 2 amps.
Using a 10 amp charger will cook them too much.
I have destroyed Jet Ski batteries using a regular car battery charger set @ 10 amps.
Old Oct 19, 2004 | 04:35 PM
Camds650's Avatar
I use a battery tender (1/2 amp charge rate) and it is automatic (senses battery voltage and keeps it at a full charge). Never have to worry about the battery being dead when it's time to ride.
Old Oct 19, 2004 | 05:34 PM
Prozack's Avatar
Yea what Cam said !!!!!!! I got two of those and they are the ticket for sure !!
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
