Lights for DS90??
Old Oct 18, 2004 | 06:38 PM
spsocal's Avatar
Default Lights for DS90??
Does anybody know of any light kit for the DS90? I noticed that there is some wiring in the front and rear that is unused, also, the key clicks over one extra click which is common for ATV lights, but I have not been able to find anything. the DS90 is an 02.
thanks
Old Oct 18, 2004 | 08:09 PM
Freakneh's Avatar
I don't know of a specific kit for that quad, however you could use an aftermarket light from Wal-mart, etc. A friend of mine set up his daughters Predator 90 with a couple. They are the "Poser" HID lights that cost around $20.00. Works pretty well...he even set them up with their own switch, instead of them coming on with the key.
J.
Old Oct 18, 2004 | 08:19 PM
Musthavefn's Avatar
The wires are not connected to the switch. I ran a wire from the battery to a light I got at Pep Boys. Mounted 1 light in the front lower opening. Welded a little bracket for it. The battery will run out of juice pretty quick. Good Luck.
Rob
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
