swingarm bushings have side to side play
Old Oct 23, 2004 | 09:56 PM
jackass650's Avatar
Default swingarm bushings have side to side play
i get horizontal play, side to side not any like the bushings are bad but like maybe there is an o ring suppose to go between the brass busings and the frame, the bushings are not wore, anyone else have this problem? thanks fellers
Old Oct 23, 2004 | 10:01 PM
01ds650's Avatar
axle nut loose?
Old Oct 23, 2004 | 10:15 PM
jackass650's Avatar
no i checked it and it is tight i was looking at my parts on the cdrom and it says there is suppose to be o rings on there maybe they fell out or got worn? how much are the swingarm bushings and o rings? thanks again fellers you all rock
Old Jun 14, 2007 | 08:02 PM
MRDS650's Avatar
Canadian and Proud of it !!!
How did you make out - I am having the same problem now. From my parts catalogue I can'e see if there is bushings in there ???
Old Jun 15, 2007 | 09:11 AM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
the o-ring is not a spacer. it is a seal that rides in the groove on the bushing. when i replaced my stock swing arm the side to side play was adjusted by tighteng up the shaft. i may be wrong with this, but mine has been like this for over 2 years and i have had no problems. as far as replaceing the o-ring, go to Ace or True Value & they will have 1 to match it up with.
MikeyBoyesq
Sep 7, 2015 10:44 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
