something wrong with my ds...
Old Oct 24, 2004 | 10:57 AM
QuadAddiction's Avatar
Default something wrong with my ds...
Ill tell ya the problem...
1)top end is kindda low!
2)i hit the throttle on 1th and it wont willie (it got speed and power) its just wierd like the first gear is over too soon... like the quad is chookin or somethin but im 90 percent sure that the carburator is fine...
i thought the clutch isnt good but i checked it too and it's fine too...
what the hell is the problem?? cdi box?? i dont know what to think...
Old Oct 24, 2004 | 12:22 PM
NickDS650's Avatar
what do u mean top end is low? What happens in 1st gear, like let it start and sit in neutral, put it in 1st, let the clutch out and go and explain what the problem is. Little better definition would help the guys on here.
Old Oct 24, 2004 | 12:34 PM
DuneMe's Avatar
Power loss shouldn't be limited to one gear. Is your power down in all gears?
If your clutch was slipping in first gear I'm pretty sure you would know it was going out in 3rd gear.
You have a 2001, have you checked your valve clearances? Probably not the issue but, if you haven't, you are due.
Put your ears to the bike. How are the bearings in the swing-arm bearing carrier?
Old Oct 24, 2004 | 01:26 PM
its no power loss... the quad flys at all gears but on the end of each gear (high rpm) the quad accelerating is not well, like its chocking.
top end is low - the top end of my quad is not as it sepuse to be its about 5-8 mph slower...
when i start riding in first gear i hit full throttle to pull it up for a whellie, when the quad is half way up its stops and kindda make a strange noise...
my english is not well and i dont know much about quads... i hope u can help me on this 1 with the information i gave you.
10x alot!
Old Oct 24, 2004 | 01:52 PM
Prozack's Avatar
If your DS is all stock then I would say that your hitting you rev-limiter.
Have you done any work to it lately?
Have you let it sit for en extended period before riding it ?
Old Oct 24, 2004 | 01:56 PM
rev limiter means the cdi box ??
well i think it set for a while (month)...
you think the problem is electricity?
Old Oct 24, 2004 | 02:29 PM
Prozack's Avatar
Yes I do mean the CDI box. Electrical could be the culprit but its still hard to say. To sit for a month isnt that bad, and if you said 6 months I might suspect the fuel.
Do you shift before it hits the rev-limit?
Is you air filter clean?
How long has it been since you had it serviced completely? By completely I mean a full tune-up with oil change and check & adjust valves?
Old Oct 24, 2004 | 02:48 PM
To the first question... ya i never got to the rev limitier...
My filter is clean and oiled [img]i/expressions/face-icon-small-smile.gif[/img]
i changed oil and oil filter last week... but the problem is more then a week...
adjust valves about 6 months maybe more...
i dont reallly think its the valves cuz i dont ride alot...
Old Oct 24, 2004 | 04:18 PM
Prozack's Avatar
Ya got me dude... Im out of questions. Without riding it and listening to it I can only guess beyond this. Sorry.
Old Oct 24, 2004 | 04:23 PM
10x anyway [img]i/expressions/face-icon-small-smile.gif[/img]
when ill find the problem ill tell you what it was...
