Compression test
Old Oct 26, 2004 | 11:20 AM
Eyal's Avatar
Default Compression test
I've red something about disabling the decompressor.
My Q is -
do I have to do it when checking the compression?
if yes, where is it and how to disable? is this specific to DS?
Thanks!
Old Oct 26, 2004 | 07:13 PM
MongoDS's Avatar
Well its one of those things that is not nessesary, but is recommended. In order to disable the compression release you are going to have to remove the valve cover. Now that its off you can see the cams, now on the cam closest to the handlebars look at the right side of it (right side if you were siting on the quad) and there the compression release sort of a small lever look'n thing that you can move in and out, you will see what Im talkin about. Take a tooth pick or something and wedge in it to hold it in place. Now do your compression test. Oh and dont forget the tooth pick[img]i/expressions/face-icon-small-blush.gif[/img]
Old Oct 26, 2004 | 08:18 PM
jackass650's Avatar
a mechanic told me i should have between 180 and 220 lbs of compression if it is still good, there is a spring behind the compression release, i cut a chort peice of rubber hose and pushed against the spring and stuffed the peice of rubber hose in the gap behind the lever then did my compression test, i got 210 lbs, i forgot to take out the rubber (one to many cocktails) had all my seat tank and covers back on and had to take them off lol good luck
Old Oct 26, 2004 | 10:06 PM
jackass650's Avatar
one question, when i disabled my decompression lever i got 210 lbs compression i stop waited 15 seconds did it again got 200 stopped did it again got 190 and the last time got 180, why did it do that does anyone know? the motor was cold hasnt been started in days and this was right after i adjusted my valves, can anyone helpme out? thanks fellas, you all rock
Old Oct 27, 2004 | 07:48 PM
Eyal's Avatar
thanks guys for your replies, I will try and let you know the results.
Old Oct 27, 2004 | 07:50 PM
jackass650's Avatar
cool thanks eyal
Old Oct 27, 2004 | 09:06 PM
Eaglecollector's Avatar
This is only a guess...but here's what I think might be the reason.
First time you did the comp test your rings and cylinder had a good film of oil on them from the last time you started the quad. Then when you did another test some of the oil film was gone. And then on the next test even less oil film.
Im thinking this is also why when you first start your quad. Don't rev her up till she's properly warmed up. Hummm never mind I won't go there...LOL[img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 27, 2004 | 09:14 PM
jackass650's Avatar
ok thanks eagle
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
bvolks
Sep 13, 2015 12:57 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
