Carb Info
Old Sep 2, 2000 | 09:30 AM
tdporter's Avatar
Can someone tell me what the lines coming off the carb are for on the DS? There are 2 small lines and 1 large line. I guess vents or something. Anyone know the real purpose?
Thanks.
Old Sep 16, 2000 | 12:23 AM
ScoobyDFW's Avatar
the black ones are vents as far as I can tell. The clear one that runs to the airbox affects the vacuum action of the throttle valve. If you leave this one off the carb won't run right.
Old Sep 16, 2000 | 12:34 AM
tdporter's Avatar
I don't have a clear one. I guess you are referring to the larger one that comes off the carb and not the two smaller ones.
I did find information on the two smaller ones. Not really sure exactly what they are for, but found a cool solution for them if you are running an open airbox, or no airbox at all.
http://www.pcracingusa.com/carvent.htm
I don't think this will really help much since I don't have a problem with bogging, but it will at least provide a filter for the vents.
Old Sep 16, 2000 | 11:11 PM
tdporter's Avatar
I am curious about the larger hose that comes off the carb. I have a K&N attached directly to the carb. Where should this hose be connected? Right now I have it connected to a automotive breather filter. It seems to run fine.
Were you saying it need vacuum on this line for it to run right?
Old Sep 17, 2000 | 11:28 PM
ScoobyDFW's Avatar
tdporter, I think you are fine with the filter on the end of the larger hose. What I was saying is, if you simply remove and discard the larger hose, when you nail the throttle, the motor will skip/hesitate.
Old Sep 18, 2000 | 11:45 AM
tdporter's Avatar
But what is the difference of just removing it vs. putting a filter on the end?
I am wondering if it would be better to have it connected to the air filter. I saw a guy once that had a DS with a K&N on the carb and he had that vent running into the back of the K&N.
If it runs better that way, then I think I should connect mine there.
What do you think?
GregM
Mar 6, 2018 06:53 AM
ltrmc02
Jul 22, 2015 04:50 AM
ghost3
Jul 19, 2015 08:46 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
