Backfire issue?
Old Nov 1, 2004 | 02:49 AM
Hez's Avatar
Hez
Default Backfire issue?
I was at Glamis this weekend on my DS and every time i shut it down and as soon as the motor stopped it made a very muffled pop, kinda like a backfire but very soft and mellow. I raised the clip all the way up and it still did it. Any ideas? i normally run at 5000 to 6000 feet elevation and no problem...........
any suggestions on the cause would be greatly appreciated.
thanks
Old Nov 1, 2004 | 10:59 AM
OregonDunePatrol's Avatar
Its usually unburned fuel in the pipe that is igniting. I've never heard of this problem when running an end cap with a stock pipe, I usually hear about this with some of the Yoshimura pipes. You might want to check your jetting, you might be a tad rich. As long as its not an engine backfire when the motor is running - which would indicate the opposite, a lean condition.
Old Nov 1, 2004 | 02:29 PM
hondabuster's Avatar
Its usually caused by a lean condition in the idle circuit. You can confirm this by pulling on the choke when you shut it off. If it stops poping, then you have a slightly lean idle circuit. Check for exhaust and intake leaks. If there arent any leaks, then id go 1/4 turn more rich on the mixture screw.
Old Nov 1, 2004 | 07:36 PM
Eaglecollector's Avatar
I would say your way to rich...I read your other post and it says your runing a 165 main in your TM45. Thats extreemly fat for even a stage 3...let alone just a end cap. Fatest main I ever ran when i had the 45 at 1000' or less was a 152. Time and again I would go back to the 150 cause it just made the best power.
edit:
Oops...that wasn't you that posted the jet size at 165...sorry bout that [img]i/expressions/face-icon-small-blush.gif[/img]
Old Nov 1, 2004 | 09:32 PM
Hez's Avatar
Hez
Hmm must be a mix up, i have the stock carb on there with stock jetting
Old Nov 1, 2004 | 09:53 PM
Yep..my mix up sorry
donintennessee
Jan 8, 2021 12:40 PM
COFatboy
May 2, 2020 12:06 AM
donintennessee
Aug 19, 2015 02:22 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
