24" haulers where to get.
the standard size typically for banshees is 25x12x9. these can be found in stock.
http://www.jimssandtoys.com/tires/tires.htm
Thanks for the info Scooby. I found some 24x11x10 extremes at www.prowlers.net. They make that tire with an 11 inch rim for the vforce. 25 were to big for my golf cart.
I have never seen 24 " paddles for a quad. Are you puttiing them on your DS? Why do you need paddles that big? what are you using now?
I have a pair of 22" extremes that i haven't got to try out yet. I have been on 21" geekos, and i am tired of getting stuck everywhere I go
well im sure you couldnt even run the stock guards, but some of the aftermarket brands might work. (or for those who just run pegs with no guards) and im not sure about the fenders... i saw 24 inch dirt tires on a ds that didnt rub, but 25 inch paddles might rub the fenders (maybe they would clear, or you could race cut the fenders)
I am putting these on a Golf cart and needed a bigger tire. Also these are the best tires for the Vforce which I have also. Douglas makes a special rim for the Vforce that is 11" wide. You have to call prowlers. They have one of the best selection of Haulers I have found and they carry them in stock. You can call Skat trac but there prices are higher. This tire is made just for the Vforce, skat also makes the 25" on a 9" rim.
