anyone tried 15tooth with stock tires
Old Dec 7, 2004 | 06:57 PM
1prokiwi's Avatar
Default anyone tried 15tooth with stock tires
Does it work okay in the trails ?? , i have to stick with the 15tooth for sand and every other day we will be riding a few trails that require normal tires . I dont want to have to change sprocket every day so hoped to leave stock tires on ?
any one else use this setup ? 15t with 20 x 11 x 9
Old Dec 7, 2004 | 07:43 PM
crazypainter's Avatar
It works just ok not good for raceing around, lose too much top end imo but easier than switching gears all the time.
Old Dec 7, 2004 | 09:38 PM
fast69's Avatar
Irun 15 all the tume Ilike the fast pull it gives me we run 300ft are so at the dunes
Old Dec 7, 2004 | 10:42 PM
JMAC650's Avatar
You could always leave it on and when your tires were out go to 22's in rear and 23's in front.
Old Dec 7, 2004 | 11:39 PM
Entomber's Avatar
15 or 14 I would be good for trails. If drag racing isn't #1 priority then go for it. What do you have to lose. You will shift sooner, and will take more input to lug the motor around. Front end will come up a tad easier as well.
Old Dec 8, 2004 | 05:28 PM
pads's Avatar
I thought my X ran better with the 16 tooth. It felt a little dead on the top end with the 15. The bike was easier to let the torque not higher rpm's pull you through.
Old Feb 28, 2005 | 12:26 PM
SCOUNDREL's Avatar
I ran some numbers on the stock gearing (16T) with 20" tires and the top speed was 83.29 MPH. (Stock)
I ran the numbers using 15T and 22" tires and the difference was the top speed was only approximately 2-1/2 MPH more at 85.89 MPH.
So where is the huge advantage for swapping out the gear and back wheels to 22"???
Old Feb 28, 2005 | 12:46 PM
JMAC650's Avatar
Ground clearance.
Old Feb 28, 2005 | 03:21 PM
tinydapimp's Avatar
I am thinking about going with a 22" hauler w/ 8 paddles to give me more clearance and traction in the sand, I have a stock '03 baja except for 1 tooth less on front sprocket. will this be fine you think for hill climbing?
Old Feb 28, 2005 | 03:28 PM
OregonDunePatrol's Avatar
1prokiwi,
I run 15T for stock sized tires on my stage II with headwork. Its very good for MX style racing and trails. As already mentioned, not good for long drags. I've also run the 14T, but I think thats too short for my current set up.
