Ds650 PIPE
Old Dec 12, 2004 | 12:51 PM
SpeedDemon13's Avatar
Default Ds650 PIPE
I need to know the best pipe for the ds650, i just want the most power that i can get from it, i dont care how loud it is, also what is the actual site for bombardier?
Old Dec 12, 2004 | 12:52 PM
choosetolose04's Avatar
Default Ds650 PIPE
What kind of riding will you be doing?
Old Dec 12, 2004 | 01:02 PM
blue250r's Avatar
Default Ds650 PIPE
The mr HP end cap is cheap easy to fit , good power gain, and loud as hell,(my can may need re packing) wear ear plugs and you will love it. check out link below. you will need to re jset but the guy is realy good with instructions
http://www.hpresearch.net/
Old Dec 12, 2004 | 01:06 PM
Default Ds650 PIPE
i ride trails and i have a lot of wide open top speed area, and i need top speed
Old Dec 12, 2004 | 01:11 PM
Default Ds650 PIPE
I agree with Blue, try the end cap from horsepower research. It should satisfy your need..[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 12, 2004 | 01:12 PM
Default Ds650 PIPE
what is the bombardier website? so u can look at specs, pics, prices, everything and how much power does that add? alls u do is take off stock one and bolt on new one?
Old Dec 12, 2004 | 01:19 PM
blue250r's Avatar
Default Ds650 PIPE
Just put bombardier in to google and you will get the bomb site but you wont find much performance parts on there.
yes Its a straight bolt on 5 min job
you might also want to concider getting your inlet manifol ported i have mine done and it makes a differance, you will see a big tourqe increase espacialy in the low 3-4 k are where the stock ds has a bit of a flat spot . the end cap is good by itself but the manifold complements it I did mine a bit at a time so i saw the differances.
Old Dec 12, 2004 | 01:21 PM
Default Ds650 PIPE
hpresearch.net will tell you all you need to know. and if you have anyquestions just call and talk to Kevin,Randall or Eric. Supernice and professional people, imo. And yes, it is as easy as bolt-on.
Old Dec 12, 2004 | 01:22 PM
blue250r's Avatar
Default Ds650 PIPE
One thing to add is you will have no spark arrestor with the end cap, just in case its an issue where you ride
Old Dec 12, 2004 | 01:25 PM
blue250r's Avatar
Default Ds650 PIPE
choosetolose04
Do you have a photo of the front of your Ds with that armadillo bumper on it, i fancy one of them myself but havent seen one mounted on ds up close
