YAY! Got the new 45.
#15
lilnotts,
this might be of help. HSR tuning manuel the very first one.HSR tuning manuel
manuels and exploded views
its a big help
its a big help
#16
#17
Ive runned the carb for almost a year now but the coldest was about 40 deg.Its been gone since thanksgiven , I will have it back Wed. I will be doing some riding over the holidays. hay you gots any way to haul that thing around yet? as for pilots I dont know PM THEBOMB he will know.
#18
#19
#20
Originally posted by: sam
is the acc. pump activated? were not to far from each other. so this is what im running right now 160 main (for colder temps) # 30 pilot, # 50 acc. pump aimed at the needle. air screw 1-1/4 out. needle on the 4 th grove. also the softer spring for the acc. pump. if the pump isnt activated the softer spring should already be in. if thats the case you might need to be about 45 on the pilot.
I havent ran it yet in this really cold air were in now, its getting some parts made for it. so the main might be able to go a little higher yet.
Im using the longer cable ,I didnt mod the stocker. if you want some pics let me know.
Sam
Also nows the time to port that intake if you havent done it yet
Sam
