baja 1000 motors
They are geared more for speed as the Baja is more of a wide open race. If you want more speed and can sacrifice a little bottom end, try 1st going up one tooth on the front sprocket. It's not too expensive to do and you can test it out. If that is too tall of gearing, go back to stock and try losing a couple of teeth out back.
Customer Service #1
May 15, 2020 08:46 AM
