Aftermarket Gear Ratio's help/info ??
Old 12-19-2004 | 08:46 PM
Dragorus's Avatar
Default Aftermarket Gear Ratio's help/info ??
What is a good factory replacement gearing for the DS650 baja...I have just received my new tires...23's up front and 22's out back.....Also if you could please explain the difference in the changes of teeth on front and back....
Old 12-19-2004 | 09:34 PM
JMAC650's Avatar
With 22's in rear I went with a 15 in front to make up the difference. It brings it almost back to stock gear ratio.
Old 12-19-2004 | 09:35 PM
blue250r's Avatar
if you check out my pics page there is a calculator for sprockets on there.
Also if you want one to work out tires as well try this
http://www.ds6 50.net/gearingcalc.htm
take the space out of the link
It is basicly less on front is lower gearing and less on back is higher gearing and vice versa
Old 12-19-2004 | 10:05 PM
Dragorus's Avatar
What's confusing to me is why would I want to change both?
Old 12-19-2004 | 10:11 PM
blue250r's Avatar
you wouldnt unless you wanted a smaller change the back has mre scope for adjustment if you see what i mean.
One on the back is a smaller percentage than one on the front
Old 12-20-2004 | 09:50 PM
Eaglecollector's Avatar
If you drop 1 tooth in the front that is almost the same as adding 3 teeth to the rear[img]i/expressions/face-icon-small-wink.gif[/img]
Old 12-21-2004 | 01:49 AM
blue250r's Avatar
Eaglecollector
Well put[img]i/expressions/face-icon-small-smile.gif[/img]
Cummins Driver
09-11-2019 02:22 PM
suzukiquadrunner1987
08-09-2015 09:45 PM
kdg723
07-25-2015 02:20 PM
toonces
07-16-2015 04:19 PM
toonces
07-11-2015 01:01 PM
