14t sprokit good bad ??
Old Dec 23, 2004 | 08:44 AM
Dunnycat's Avatar
Default 14t sprokit good bad ??
What are the pros and cons of useing 14t with 22" rear tire
Old Dec 23, 2004 | 08:48 AM
TheChosenOne's Avatar
That would result in shorter gearing, meaning faster accelleration, but loss of top end. You may find that you're shifting through the gears too fast. With a 15 tooth and 22" rears, you almost achieve the same ratio as stock. Just a bit shorter.
Old Dec 23, 2004 | 08:58 AM
Dunnycat's Avatar
Ya im running 15t with 22" now. I was wanting to try 14t I heard that the 14 is hard on the chain, is that true?
Old Dec 23, 2004 | 09:38 AM
That I don't know. I'm gonna shove a 14 tooth on with 20" tires when I get the quad back together. Just for shlts and giggles see what happens.
Old Dec 23, 2004 | 10:50 AM
sam's Avatar
sam
I ran the 14/ 22 combo for dirt drags and it helped alot. I trail road w/ it for a bit to it wasnt to bad. went through the gears quicker lost a little on top. but it was snappier. I recomend trying it. NOTE the engine mount bolt right behind the sprocket should be turned around the chain will rub on it.
Sam
Old Dec 23, 2004 | 11:48 AM
Sam, nice one on the bolt pointer, that would save a lot of time and some headaches. hats off on that one.
Old Dec 23, 2004 | 12:48 PM
shmee's Avatar
can you get a 520 14t sprocket??
Old Dec 23, 2004 | 05:18 PM
OregonDunePatrol's Avatar
I ran a 14T for two years with 20" tires. No problems with anything - very short gears - first was pretty much a non-gear. But that was the perfect combination where I was racing. I now am 15/40 with 20" 8 paddle extremes - its better for cruising and still has plenty of low end.
Old Dec 23, 2004 | 07:25 PM
VEGAS650's Avatar
I used to run 15/42 but after the rear one wore out, I decided it would be cheaper to get a 14 and put the 40 back on the rear.
No problems with it either.
Old Dec 24, 2004 | 02:26 PM
Dunnycat's Avatar
Well, I put the 14t on and I did not have to turn the bolt around the nut end was on the other side the bolt head end is near the sprockit maybe from factory they switch around.So the chain did not rub. I think Im going to like it sence I ride in tight woods. Thanks for yall's responce...
Nondem
Feb 22, 2020 12:20 PM
Unzzy66
Jul 11, 2015 10:01 PM
cornermike
Jul 8, 2015 11:44 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
