Rev. limit on Vortex CDI...
These are what mine came with.
Switch Position Switch Map Name Power Type Rev Limit RPM
POWER MAP 1 1 ds65x1t1.igc Performance Map 8,350
TRACTION MAP X10 2 ds65x1t2.igc Traction 8,350
TRACTION MAP X10 3 ds65x1t3.igc Traction 8,350
TRACTION MAP X10 4 ds65x1t4.igc Traction 8,350
TRACTION MAP X10 5 ds65x1t5.igc Linear Power 8,350
TRACTION MAP X10 6 ds65x1t6.igc Linear Power 8,350
TRACTION MAP X10 7 ds65x1t7.igc Performance Map 8,350
TRACTION MAP X10 8 ds65x1t8.igc Standard Map 8,100
TRACTION MAP X10 9 ds65x1t9.igc Standard Map 8,400
TRACTION MAP X10 0 ds65x1t0.igc Standard Map 8,600
My reprogrammed vortex has the following REV Limits.
Curve #1 - 9,700RPM
#2 - 5,200RPM
#3 - 5,600RPM
#4 - 6,100RPM
#5 - 6,600RPM
#6 - 7,000RPM
#7 - 7,500RPM
#8 - 8,100RPM
#9 - 8,600RPM
#10 - 9,100RPM
I can launch anywhere from 5,200RPM to 9,700RPM
It all depends on the track @ what RPM's I want launch at. I like choice's
Curve #1 - 9,700RPM
#2 - 5,200RPM
#3 - 5,600RPM
#4 - 6,100RPM
#5 - 6,600RPM
#6 - 7,000RPM
#7 - 7,500RPM
#8 - 8,100RPM
#9 - 8,600RPM
#10 - 9,100RPM
Here is what the packaging says is standard from Vortex ...
Handle Bar Switch: Power
CDI Position switch 1
Performance Map: rev limit at 8,900
Handle Bar Switch: Traction
CDI Position Switch 2
Traction : rev limit at 8,350
CDI Position Switch 3
CDI Position Switch 4
CDI Position Switch 5
Linear Power: rev limit at 8,350
CDI Position Switch 6
CDI Position Switch 7
Performance Map: rev limit at 8,350
CDI Position Switch 8
Standard Map with Rev Limit at 8,100 RPM
CDI Position Switch 9
Standard Map with Rev Limit at 8,400 RPM
CDI Position Switch 0
Standard Map with Rev Limit at 8,600 RPM
Steeldon
09-09-2015 09:38 AM
