alum rear sprocket.
Old 01-23-2005 | 01:10 AM
shmee's Avatar
Default alum rear sprocket.
anyone using one? holding up?
Old 01-23-2005 | 11:48 AM
sand45's Avatar
In the sand a aluminum sprocket from sprocket specialist would last me about 6 months on my ds. Thats going out about every other weekend .
Old 01-23-2005 | 12:19 PM
SANDMAN430's Avatar
chain adjustment has a lot to do with it.
Old 01-23-2005 | 12:53 PM
shmee's Avatar
ya, i have one comming from ron wood.
Old 01-23-2005 | 02:09 PM
crazypainter's Avatar
what size are you putting on?
Old 01-23-2005 | 03:37 PM
shmee's Avatar
40, but i think im going to get the 42 and run a 16-42 gearing when on alky.
Old 01-23-2005 | 04:28 PM
VEGAS650's Avatar
Yes, chain adjustment has ALOT to do with it.
I wore out two of them before I learned how to properly adjust the chain. I always ran it too loose.
Also, I was using sidewinders stainless chain.
Since I got rid of that chain and kept it properly tentioned, I've had no problems.
Old 01-23-2005 | 10:24 PM
How much difference is there between a 15/40 and a 16/42 whats the advantage of one over the other
Old 01-23-2005 | 10:29 PM
shmee's Avatar
the 16-42 is between 15-40 and 16-40. with the 16 front the chain dont turn so tight. and on alky when leaving at 6000 rpm i think it will pull it in second.
Old 01-23-2005 | 10:35 PM
I can pull a 16/40 second gear start at mega RPM but I hate to cause I'm afraid I'm being to hard on the clutch and if I dont rev the crap out of her she bogs BAD
caveeagle
09-19-2015 02:20 PM
Chasso
2) Chassis problems..
09-19-2015 04:06 AM
bmark0610
ATC 3-Wheelers
09-07-2015 08:57 PM
