Is there way to Unseize an Engine
Old Jan 25, 2005 | 08:27 PM
Oldmanracing's Avatar
Default Is there way to Unseize an Engine
Pull the head.
Remove cylinder nuts and raise barrel 1/2 to 3/4 inch
What ever you can raise put wood between bottom of barrel and top of cases.
Place 2 inch or larger brass plug against piston.
Hit plug sharply with a small hammer. You want to shock the piston without causing other failures.
This should cause a fracture between piston and liner.
Pull barrel off.
Old Jan 29, 2005 | 10:17 PM
alltoys's Avatar
Well I finaly got it to break lose. I used pure Kerosene filled the top and put a little air pressure to it and filled the crank case. After 4 days it started to move a little and this being Saturday I could almost turn it all the way around. Tomorrow it will go all the way hopefully then I can rip it apart. Had this not worked then I would have tried heat and what Olmanracing had commented on. Thanks all for your help once I have it apart will let you all know how it looked inside.
Old Feb 4, 2005 | 05:47 PM
crackerJack's Avatar
You get that thing un seized?? How is it running. I may be interested in the engine if you didn't.
Old Feb 4, 2005 | 11:17 PM
alltoys's Avatar
CrackerJack,
Yes totaly unseized, runing and sold!!
Old Feb 5, 2005 | 04:26 AM
  #15
SpinCycle's Avatar
Hope you didn't sell it to a friend...
Old Feb 5, 2005 | 11:53 PM
  #16
alltoys's Avatar
As a matter of fact it was to a friend and he nows exactly was done to the engine not only that he helped me to get it going. There was far more moneys involved with this engine than what I sold it to him for. At least it does run and it actually runs pretty well. He is happier than a pig in poo he couldn't have purchased another engine for what I sold to him for plus all the extras that came with it.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
