Got my new steering stem today how hard to replace?
Old Feb 24, 2005 | 01:36 PM
jackass650's Avatar
Default Got my new steering stem today how hard to replace?
are there any secrets or anything i need to know before i replace it and the new bearing? thanks fellas
Old Feb 24, 2005 | 02:00 PM
JEFFROE's Avatar
i have done it both ways hard and not so hard. remove the handle bars and fuel tank, take off the front plastic for easy access. i think i loosened the oil tank and headlight also, that will make things alot easier.
Old Feb 24, 2005 | 03:08 PM
jackass650's Avatar
ok thanks jeffroe
Old Jul 1, 2005 | 07:16 PM
mudnuri's Avatar
I cannot get mine out. I have everything off. The bottom where the tie rods connect will not come out of the frame.
Old Jul 1, 2005 | 07:18 PM
JEFFROE's Avatar
there is a nut under the frame that connects the stem to the pocket it sit's in. loosen that and it will come out the top.
Old Jul 1, 2005 | 07:36 PM
mudnuri's Avatar
I have that off. The stem is loose. I can only move it around so much and thats it. It won't come out of the frame. It's boxed in. When I move the top all the way over to the left or right, it's not enough to manuver it out. The brace for the shocks seems to be in the way. I had to come in and take a break before I broke something.
Old Jul 1, 2005 | 08:11 PM
mudnuri's Avatar
I wrestled with it some more and think I am going to have to cut the stem at the bottom. In the manual it just says to "pull steering column" after you remove the other stuff.
Now that I have my new stem, I am wondering if I should do what some of you have done and take it to a shop and have them switch the stem to cromoly? What would be the point? Stronger?
Old Jul 1, 2005 | 08:18 PM
Slowride's Avatar
Seems like if you rotate the stem side of the cleat toward front right corner and force it up, it'll come. The stem side came out first, and I had to force the neck toward the tank and push pretty good to get the bottom the angle to pop out.
I walked away from it after 15 minutes. Then went back and it came right out.
good luck.
Old Jul 1, 2005 | 08:48 PM
mudnuri's Avatar
Thanks guys, I had to pack it up for tonight. I was getting pretty frustrated and the mosquitos weren't any help.
My cleat is bent slightly and so is the tie rod end. The stem is, too.
Old Jul 1, 2005 | 09:01 PM
midnite's Avatar
I had to twist, and try all angles for 20 mins to get mine out. If I remeber right, the new one went in just as tough.
