master link technique
Old Feb 27, 2005 | 08:41 PM
atvaddict01's Avatar
Default master link technique
I cant seem to get mine tight enough to slide the clip on.Any ideas
Old Feb 27, 2005 | 09:37 PM
busmechanic's Avatar
chain press tool by motion pro. or make one.
Old Feb 28, 2005 | 01:24 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Try clamping it together with vise grips.
Old Feb 28, 2005 | 07:37 AM
cpaul's Avatar
Chain press tool that Bus is talking about is the best $20 or $30 you will ever spend!
Old Feb 28, 2005 | 07:53 AM
the one I have is the small press in this link. the fourth pic down. on the right. $24.90 got it at the local yamy shop for $19.99 allthough a complete kit would be nice to have.
Old Feb 28, 2005 | 08:26 PM
Thanks guys should have an early day at work tommorow.Ill go check out the
parts dealer by me.
Old Mar 1, 2005 | 12:28 AM
Teebone56's Avatar
Needle nose vise grips work really well[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 1, 2005 | 12:38 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Get a 10 MM nut and place it between the pins on your master link clamp it down with a pair of vice grips let it sit for a few minutes and the clip will slide on very easy.
Hope this helps.
Old Mar 1, 2005 | 01:01 PM
SCOUNDREL's Avatar
Mini Chain Breaker & Mini Chain Press Tool.
The 08-0001 is for 420 to 630 chain. It will push the link pin completely through the link. The handle folds away for easy storage and the replaceable pin (08-0002) is heat treated for strength and wear resistance.
08-0001: $27.10 for the set from Motion Pro.
Old Mar 1, 2005 | 08:04 PM
Nicname's Avatar
I have used a small C-Clamp for years, works as well as many other ideas I have seen. Best tool I ever found in a parking lot...
