HMF Jetting
Old Mar 6, 2005 | 12:00 AM
CrimsonFlyer's Avatar
Default HMF Jetting
I am looking to put an HMF on my DS those of you that have this already what was your stock carb with K&N jetting? I was also curious lid on or off? Thanks for the tips.
Old Mar 6, 2005 | 02:28 AM
Hightower's Avatar
Default HMF Jetting
I think MRHP says run 175 mikuni main jet, stock needle clip on 5th groove (bottom), keep airbox lid on for best performance due to stock carb being a vacuum slide.
Old Mar 6, 2005 | 10:16 AM
DesertViper's Avatar
Default HMF Jetting
What I found works best for me, at 3000 to 6000 ft elevation, is to run the stock pilot jet; one clip position richer on the needle; and the stock main jet. When I am required to run with the spark arrestor for desert racing, I will also run with the stock airbox lid on, and it runs really good. But it does not have quite as crisp of a response, or feel like it has quite as much power as it does with the spark arrestor out, and a free flowing Outerwear style airbox lid in place, which is the set-up I use at the dunes. And I run with the same jetting, whether I am running with or without the stock airbox lid, or the HMF spark arrestor.
DesertViper
Old Mar 8, 2005 | 03:14 AM
TriSum's Avatar
Default HMF Jetting
I was a little amazed at what jetting I ended up with on my HMF. I run a Dynojet 205 with a Dynojet needle on the top position. I'm not finished with the tuning yet, (my RPM pick up on my Dyno took a crap). I don't run an airbox either, just a K&N. I have over 20 hours on the Dyno playing with this combo. It works really well, I went from losing to my two buddies, (TRX 450 and Predator, both piped) to being able to drive around them. If you spend the time, this carb will work without the airbox.
Old Mar 8, 2005 | 05:05 PM
Coyoteman's Avatar
Default HMF Jetting
I run a 170 main(Mikuni jet), needle in the richest position, stock pilot, airbox lid on. I ride 500 to 1400 ft above sea level.
All these are suggestions that will get you in the ballpark, you will have to tune it in from there.
Old Feb 6, 2006 | 10:46 PM
1BigDSRider's Avatar
Default HMF Jetting
Bump for dsrider6666.
Old Feb 20, 2006 | 06:44 PM
bombaman's Avatar
Default HMF Jetting
I'd like know what the symtoms are if you're rich or lean after putting on the pipe???
Old Feb 20, 2006 | 08:44 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Default HMF Jetting
CV General Carb Symptoms
This is some good training material.
Then search for Stock Carb Mods
OMR
Old Feb 20, 2006 | 10:12 PM
bombaman's Avatar
Default HMF Jetting
awesome!!!
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
