Which Oil ?
Which Oil ?
Originally posted by: SCOUNDREL
The best Synthetic is Redline.
"If you don't have performance clutch springs, then don't run synthetic. It can cause clutch slippage." WRONG
Which Oil ?
Nope! OLD GUY!...lol
I'm not going to get in a pissing contest with you. I have tried and used nearly every quality synthetic oil in a variety of bikes, cars and custom offroad vehicles. In some cases I will agree that SOME synthetic oils should not be used in a wet clutch system. Many have friction modifiers including graphite and Teflon additives. These should never be used because there intent is to reduce friction, hence the name "Friction modifiers" Obviously this is not a good thing in a wet clutch. However Redline does not use friction modifiers and if you research what the industry says you will see that not all oils are created equal.
#17
#18
Which Oil ?
I have done three oil changes in my Bomb 2005 and all the oils have been different with different results. First I tried the Bombardier 10w-40 that the manufacture recommends. It ran okay. When the oil got hot the clutch ran hard, slammed into gear every once in a while. Then I ran spectro 20w-50. It did better then the bombardier 10w-40 the clutch ran good had no problems. I am trying Honda GN4 20w-50 because it was cheaper per gallon. It runs okay, the clutch feels a little bit rougher, but it works. I think from now on after this last change I am going to stick with Spectro 20w-50 for summer and 10w-40 for winter. Spectro seemed to be a good oil and it was only 4.99 a quart. Much better then $6.88 (bombardier) and $7.00 for HP4 no molly a quart.
#20
Which Oil ?
